Image #1 Image #2
Add Note Edit Step 33 — Earpiece Speaker Assembly  ¶
  • Use the edge of a plastic opening tool to peel the earpiece speaker off the foam adhesive securing it to the iPhone.
  • If you wish to reuse the earpiece speaker, try not to tear the foam adhesive that secures it to the iPhone's case.
  • Remove the earpiece speaker.
Image #1
Add Note Edit Step 34 — Power and Sensor Cable  ¶
  • Use the edge of a plastic opening tool to separate the power button contact from its plastic bracket.
Image #1
Add Note Edit Step 35  ¶
  • Power and sensor cable remains.
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Flathead 3/32" or 2.5 mm Screwdriver
$6.95 · 48 In stock
Plastic Opening Tools
$2.95 · 50+ In stock
iPhone 5-Point Pentalobe Screwdriver
$12.95 · 50+ In stock
Related Products
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 10 In stock
