Installing iPhone 4 Verizon Rear Panel
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Replace a cracked rear panel on your iPhone 4 Verizon.
  • Add Note x
  • x 42
Remove the rear panel to access the internal components of your iPhone.
Image #1
Add Note Edit Step 1 — Rear Panel  ¶
  • Before disassembling your iPhone, be sure it is powered off.
  • Remove the two 3.6 mm Pentalobe screws next to the dock connector.
  • During reassembly, we recommend you replace the 5-point screws with equivalent Phillips screws. Our Liberation Kit provides the tools and screws needed to replace the Pentalobe screws with Phillips screws.
  • The 5-Point Screwdriver should only be used once, as it has the potential to strip the screws.
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Push the rear panel toward the top edge of the iPhone.
  • The panel will move about 2 mm.
Image #1
Add Note Edit Step 3  ¶
  • Pull the rear panel away from the back of the iPhone, being careful not to damage the plastic clips attached to the rear panel.
  • Remove the rear panel from the iPhone.
Required Tools
iPhone 5-Point Pentalobe Screwdriver
$12.95 · 50+ In stock
Related Products
