Installing iPhone 4 Verizon Power Button
Replace the metal power button cover on your Verizon iPhone 4.
- Author: Andrew Bookholt
- Difficulty: Difficult
Use this guide to replace the metallic outer power button on your iPhone.
Sections
- Rear Panel 3 steps
- Battery 3 steps
- Dock Connector Cable 5 steps
- Rear Camera 3 steps
- Logic Board 9 steps
- Power Button 2 steps
- View:
- Single page
Edit
Step 1
Rear Panel
Before disassembling your iPhone, be sure it is powered off.
Remove the two 3.6 mm Pentalobe screws next to the dock connector.
During reassembly, we recommend you replace the 5-point screws with equivalent Phillips screws. Our Liberation Kit provides the tools and screws needed to replace the Pentalobe screws with Phillips screws.
The 5-Point Screwdriver should only be used once, as it has the potential to strip the screws.
Page 1 of 4
