Installing iPhone 4 Rear Panel
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Rear Panel replacement.
  • Add Note x
  • x 408
Remove the rear panel to access components inside your iPhone 4.
Files
Tools
Image #1 Image #2
Add Note Edit Step 1 — Rear Panel  ¶
  • Your iPhone 4 rear cover may have either two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws (second image). Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
  • Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
  • During reassembly, we recommend you replace the 5-point screws with equivalent Phillips screws. Our Liberation Kit provides the tools and screws needed to replace the Pentalobe screws with Phillips screws.
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Push the rear panel toward the top edge of the iPhone.
  • The panel will move about 2 mm.
Image #1
Add Note Edit Step 3  ¶
  • Pinch the rear panel with your fingers and lift it away from the iPhone.
Required Tools
Phillips #000 Screwdriver
$9.95 · 50+ In stock
iPhone 5-Point Pentalobe Screwdriver
$12.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 17 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
Popular Device Products
iPhone 4 Replacement Battery
$24.95 · 50+ In stock
iPhone 4 Display Assembly (GSM/AT&T)
$94.95 · 50+ In stock
iPhone 4 Home Button Assembly
$14.95 · 50+ In stock
iPhone 4/4S Liberation Kit
