iPhone 4 Rear Camera Replacement
  1. iPhone 4 Rear Camera Replacement, Rear Panel: step 1, image 1 of 2 iPhone 4 Rear Camera Replacement, Rear Panel: step 1, image 2 of 2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Your iPhone 4 rear cover may have either two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws (second image). Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
    • Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
    • Be sure the driver is well seated when removing Pentalobe screws, they are very easy to strip.
  2. iPhone 4 Rear Camera Replacement: step 2, image 1 of 2 iPhone 4 Rear Camera Replacement: step 2, image 2 of 2
    • Push the rear panel toward the top edge of the iPhone.
    • The panel will move about 2 mm.
  3. iPhone 4 Rear Camera Replacement: step 3, image 1 of 1
    • Pinch the rear panel with your fingers and lift it away from the iPhone. Alternatively, use a Small Suction Cup .
    • Be careful not to damage the plastic clips attached to the rear panel.
    • If you are installing a new rear panel, be sure to remove the plastic protective sticker from the inside of the camera lens and the sticker from the large black area near the lens.
  4. iPhone 4 Rear Camera Replacement, Battery: step 4, image 1 of 1
    • Remove the single 2.5 mm Phillips screw securing the battery connector to the logic board.
    • Some devices may have two screws, one of which holds down the contact pad which is located above the screw indicated in red in the photo.
  5. iPhone 4 Rear Camera Replacement: step 5, image 1 of 1
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Pry from the top and bottom of the connector bracket—there isn't as much of an overhang on the sides, and you may damage the connector.
    • Be very careful to only pry up on the battery connector and not the socket on the logic board. If you pry up on the logic board socket, you may break it entirely.
    • Remove the metal clip covering the antenna connector.
  6. iPhone 4 Rear Camera Replacement: step 6, image 1 of 3 iPhone 4 Rear Camera Replacement: step 6, image 2 of 3 iPhone 4 Rear Camera Replacement: step 6, image 3 of 3
    • Use the clear plastic pull tab to gently lift the battery out of the iPhone.
    • If the tab breaks before the battery is freed, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery. Wait about one minute for the alcohol solution to weaken the adhesive. Carefully slide a spudger under the battery tab to release the adhesive.
    • Prying in other places may cause damage. Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the the ribbon cable.
    • Before reconnecting the battery connector, be sure the contact clip (shown in red) is properly positioned next to the battery connector.
    • Before reassembly, clean metal-to-metal contact points with a de-greaser such as windex. The oils from your fingers have the potential to cause wireless interference issues.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
  7. iPhone 4 Rear Camera Replacement, Rear Camera: step 7, image 1 of 1
    • Remove the following five screws securing the connector cover to the iPhone:
    • One 2.3 mm Phillips
    • Two 1.6 mm Phillips
    • One 1.4 mm Phillips
    • One 4.8 mm Phillips
    • Remark: in order to remember their proper positions, it might be helpful to draw 5 circles on a sheet of paper, placing each screw in the corresponding circle.
  8. iPhone 4 Rear Camera Replacement: step 8, image 1 of 3 iPhone 4 Rear Camera Replacement: step 8, image 2 of 3 iPhone 4 Rear Camera Replacement: step 8, image 3 of 3
    • Use an iPod opening tool to slightly lift the top edge of the connector cover away from the logic board.
    • Use the tip of a spudger to pull the connector cover retaining clips away from the inner frame.
    • Remove the connector cover from the iPhone.
    • Before reassembly, be sure to clean all metal-to-metal contact points on the connector cover with a de-greaser such as windex. The oils on your fingers have the potential to cause wireless interference issues.
    • There is a tiny metal part on the top screw hole, make sure this stays on. It's a key part of the wireless and GPS antenna.
  9. iPhone 4 Rear Camera Replacement: step 9, image 1 of 1
    • Use an iPod opening tool to carefully lift the rear camera connector up off its socket on the logic board.
  10. iPhone 4 Rear Camera Replacement: step 10, image 1 of 2 iPhone 4 Rear Camera Replacement: step 10, image 2 of 2
    • Remove the rear camera from the iPhone avoiding to move some of the connectors to the right.
    • After reinserting the new camera, verify these connectors if the IPhone does not power on.
    • Remark: The battery (not shown on the photos) should be disconnected but doesn't need to be removed entirely.
193 other people completed this guide.
Attached Documents
11 Guide Comments
This was super simple. My camera was not focusing after a previous company replaced it due to a faulty flash. I decided to take things into my own hands...no pun intended.
The instructions are super simple and easy to follow. Be aware of the loose clip under the connector - mine flew out - and I was worried I wouldn't figure out how to get it back in.
I also had to use a #0 screwdriver...#00 was too large.
I couldn't get the battery out...so, I was just super careful that the phone was off, and remained off during the repair.
Out with the defective camera...in with the functioning camera...replaced a couple of screws and the battery connector. Tested the camera prior to replacing everything.
Thank you ifixit!
You ROCK!!!
TechxaSolutions - Reply
great comment!. You Rock!
Luca -
Hi guys. I just did it ! I would not describe it as super easy, but thanks to the screw template provided file, even the now famous pressure contact can not be lost ;-)
I just wanted to comment, not only to praise iFixit (and myself), but also to mention two side effects I had to overcome:
-First, when finished, the power button did not work (I had to plug the Dock Connector to start the phone). As I the power button is not so far from the rear camera, I figured out something went wrong in the reassembly. Since I had just done it once, I thought I could do it a second time, so I removed the newly assembled camera and reassembled it with extra caution. At the end, the power button worked as expected.
-Second: each time I restarted the phone after reassembly (twice, then), the SIM card would not unlock after the PIN code was entered. I had to remove and reinsert the SIM card for the PIN code to finally unlock it.
Otherwise, everything went smoothly, thanks again to the iFixit guys !
tibomartinperso - Reply
Fantastic!!! my problem was the rear camera, when i switch on the camera app the screen were completely black and the torch was not working at all! I buyed the tools and the rear camera everything arrived here in Italy in perfect time as scheduled and in one hour I did the job !!! now my iphone camera is perfectly up and running !!! thanks to IFIXIT.COM and their guides!
vflip - Reply
hello guys ! I have done the replacement correctly because my camera wasn't able to focus anymore ! But now the flash light isn't working anymore :(( what can i do ?
Sincerly,
Antoine
antoinevalen - Reply
Past 24 Hours: 8
Past 7 Days: 278
Past 30 Days: 683
All Time: 326,355
