Installing iPhone 3G Earpiece Speaker
Replace your iPhone 3G's earpiece speaker.
  • Add Note x
  • x 9
Has your ear speaker stopped working? Follow this guide to install a new one.
Image #1
Add Note Edit Step 1 — Display Assembly  ¶
  • Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
Image #1
Add Note Edit Step 2  ¶
  • Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
  • Be very careful when opening the iPhone so that the cables under the display are not severed.
  • There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly.
  • Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
  • If the display assembly is too damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape may be used.
Image #1
Add Note Edit Step 3  ¶
  • The display assembly is still connected to the iPhone by several cables, so don't try to remove it entirely just yet.
  • Rotate the display assembly up until it is at an angle of approximately 45 degrees.
Image #1
Add Note Edit Step 4  ¶
  • Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
Image #1
Add Note Edit Step 5  ¶
  • Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
  • Use a spudger to disconnect the black ribbon cable labeled "2."
Image #1
Add Note Edit Step 6  ¶
  • Use a spudger to flip up the black plastic tab holding the remaining ribbon cable in place. The black will rotate up 90 degrees, releasing the ribbon cable.
  • The tab is very fragile, so be careful when flipping it up to unlock the cable and down to lock the cable.
  • The plastic tab may be white (instead of black) on some iPhone models.
  • Slide the ribbon cable out of its connector, and remove the display assembly from the iPhone.
Image #1
Add Note Edit Step 7 — Earpiece Speaker  ¶
  • Remove the single Phillips #00 screw from the corner of the display assembly.
Image #1 Image #2 Image #3
Add Note Edit Step 8  ¶
  • Use the flat end of a spudger to pry up the right side of the ear speaker cover assembly.
    • Do not try to pry the assembly all the way off, as it is still connected at two points.
  • Turn the spudger around and use the pointed side to detach the two clips securing the top of the assembly.
  • Once the clips are detached, lift the cover assembly up from the device.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Small Suction Cup
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 13 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
Popular Device Products
iPhone 3G Replacement Battery
$14.95 · 50+ In stock
iPhone 3G and 3GS Mute Button
iPhone 3G and 3GS Volume Button
$4.95 · 43 In stock
iPhone 3G and 3GS Power Button
$4.95 · 23 In stock
SIM Card Eject Tool
