Image #1
Add Note Edit Step 25  ¶
  • Hold both the battery and the logic board assembly and slide both parts away from the orange antenna and out of the iPhone.
Image #1
Add Note Edit Step 26  ¶
  • Remove the three Phillips #00 screws securing the front bezel to the iPhone.
Image #1
Add Note Edit Step 27  ¶
  • Rotate the iPhone 90 degrees and remove the two Phillips #00 screws from the bottom of the iPhone.
Image #1
Add Note Edit Step 28  ¶
  • Rotate the iPhone 90 degrees and remove the three Phillips #00 screws from the side of the iPhone.
Image #1
Add Note Edit Step 29  ¶
  • Rotate the iPhone 90 degrees and remove the two Phillips #00 screws from the top of the iPhone.
Image #1
Add Note Edit Step 30  ¶
  • Lift the front bezel away from the iPhone.
Image #1
Add Note Edit Step 31  ¶
  • Display assembly remains.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Metal Spudger
Plastic Opening Tools
SIM Card Eject Tool
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 17 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
Popular Device Products
iPhone Gen 1 Replacement Battery
$14.95 · 50+ In stock
SIM Card Eject Tool
