iPad Mini CDMA Front Facing Camera Cable Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad Mini CDMA Front Facing Camera Cable Replacement, Front Facing Camera Cable: step 1, image 1 of 2 iPad Mini CDMA Front Facing Camera Cable Replacement, Front Facing Camera Cable: step 1, image 2 of 2
    • Use a pair of tweezers to peel up and remove the small piece of tape covering the front-facing camera cable connector.
  2. iPad Mini CDMA Front Facing Camera Cable Replacement: step 2, image 1 of 1
    • The front-facing camera cable connector is secured with pieces of tape that wrap up around the sides of the cable and are fastened to two small metal plates.
    • In the next two steps, you will be prying the two metal plates up and out from the center of the cable.
  3. iPad Mini CDMA Front Facing Camera Cable Replacement: step 3, image 1 of 3 iPad Mini CDMA Front Facing Camera Cable Replacement: step 3, image 2 of 3 iPad Mini CDMA Front Facing Camera Cable Replacement: step 3, image 3 of 3
    • Use a plastic opening tool to gently pry the lower metal plate up from the front-facing camera cable connector.
    • Being careful not to break the plate or the tape attached to it, pry it up and fold it away from the front-facing camera cable connector.
  4. iPad Mini CDMA Front Facing Camera Cable Replacement: step 4, image 1 of 3 iPad Mini CDMA Front Facing Camera Cable Replacement: step 4, image 2 of 3 iPad Mini CDMA Front Facing Camera Cable Replacement: step 4, image 3 of 3
    • Gently pry the second metal plate up from the front-facing camera cable connector.
    • Again, carefully pry the plate up and away from the front-facing camera cable connector.
  5. iPad Mini CDMA Front Facing Camera Cable Replacement: step 5, image 1 of 2 iPad Mini CDMA Front Facing Camera Cable Replacement: step 5, image 2 of 2
    • Use a plastic opening tool to pry the front-facing camera cable's connector up from its socket on the logic board.
  6. iPad Mini CDMA Front Facing Camera Cable Replacement: step 6, image 1 of 3 iPad Mini CDMA Front Facing Camera Cable Replacement: step 6, image 2 of 3 iPad Mini CDMA Front Facing Camera Cable Replacement: step 6, image 3 of 3
    • Use a pair of tweezers to peel up the top of the rectangular piece of tape covering the bend in the front-facing camera cable.
    • Do not try to remove the tape, as it is connected below the cable.
    • Bend the tape up out of the way of the front-facing camera cable.
  7. iPad Mini CDMA Front Facing Camera Cable Replacement: step 7, image 1 of 2 iPad Mini CDMA Front Facing Camera Cable Replacement: step 7, image 2 of 2
    • Gently fold the front-facing camera cable upwards (roughly at a 90-degree angle), exposing the bottom side of it.
  8. iPad Mini CDMA Front Facing Camera Cable Replacement: step 8, image 1 of 3 iPad Mini CDMA Front Facing Camera Cable Replacement: step 8, image 2 of 3 iPad Mini CDMA Front Facing Camera Cable Replacement: step 8, image 3 of 3
    • While holding the front-facing camera cable up, use the tip of a spudger to separate the piece of tape adhered to the bottom side of the corner of the cable.
    • The tape is folded in half to attach to both the underside of the front-facing camera cable and the top side of the cable directly beneath it (headphone jack cable).
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 594
