Installing iMac Intel 27" EMC 2309 and 2374 RAM
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
iMac Intel 27" EMC 2309 and 2374 and 2390 RAM replacement.
  • Add Note x
  • x 49
Upgrade RAM modules for an instant boost in speed.
Image #1 Image #2
Add Note Edit Step 1 — Access Door  ¶
  • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
  • These screws will remain captive in the access door.
  • Remove the access door from your iMac.
  • During reassembly, fasten the access door loosely and align it with the pocket cut into the outer case of the iMac before fully tightening the screws.
Image #1
Add Note Edit Step 2 — RAM  ¶
  • Use your fingers or the tip of a spudger to slide the black plastic RAM tray pull tab out of the RAM slot.
Image #1 Image #2
Add Note Edit Step 3  ¶
  • Pull the black plastic tab away from the iMac to eject the RAM chip from its socket.
    • The RAM modules are firmly seated and may require a fair amount of force to remove.
  • Use your fingers to slide the RAM chip out of its socket.
  • If necessary, repeat this process for the other RAM module(s).
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #1 Screwdriver
$4.95 · 6 In stock
Related Products
PC3-8500 2 GB RAM Chip
$49.95 · 11 In stock
PC3-8500 4 GB RAM Chip
$99.95 · 21 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 25 In stock
Inspection Scope
$39.95 · 39 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 18 In stock
