Installing iMac Intel 24" EMC 2267 Dual Drive
  1. Installing iMac Intel 24" EMC 2267 Dual Drive, Access Door: step 1, image 1 of 1
    • Lay your iMac front side down on a table with the lower edge facing yourself.
    • Loosen the single Phillips screw in the center of the access door.
    • This screw is captive in the access door.
    • Remove the access door from your iMac.
  2. Installing iMac Intel 24" EMC 2267 Dual Drive, Glass Panel: step 2, image 1 of 2 Installing iMac Intel 24" EMC 2267 Dual Drive, Glass Panel: step 2, image 2 of 2
    Tool used on this step:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Buy
    • The glass panel is fixed onto the front bezel with fourteen magnets around its perimeter.
    • Stick two suction cups to opposing corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
  3. Installing iMac Intel 24" EMC 2267 Dual Drive: step 3, image 1 of 1
    • Gently pull the glass panel straight up off the iMac.
    • The glass panel has several positioning pins around its perimeter. To avoid shearing these pins off the glass panel, be sure to only pull straight up during removal.
    • Be meticulous about cleaning the LCD and the inside face of the glass panel before reinstallation, as any fingerprints or dust trapped inside will be annoyingly visible when the display is on.
    • When replacing the glass, be sure there's nothing between the glass and the frame. Stray cables could be damaged or crack the glass.
  4. Installing iMac Intel 24" EMC 2267 Dual Drive, Front Bezel: step 4, image 1 of 1
    • Remove the following 12 screws securing the front bezel to the rear case:
    • Eight 13 mm T8 Torx.
    • Four 25 mm T8 Torx.
    • On the 24" iMac Intel Model A1225, the bottom center two screws are long (26mm), four on sides (two left, two right) are medium (18mm), and the remaining 6 (four top, two bottom corners) are short (14mm).
  5. Installing iMac Intel 24" EMC 2267 Dual Drive: step 5, image 1 of 2 Installing iMac Intel 24" EMC 2267 Dual Drive: step 5, image 2 of 2
    • The front bezel is still attached to the iMac by the microphone cable.
    • Gently lift the front bezel from its top edge off the rear case.
    • Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
    • Rotate the front bezel away from the rest of the device and lay it above the top edge of the iMac.
    • When reinstalling the front bezel, start at the lower edge and make sure it is flush with the rear case before lowering the top edge onto the iMac.
  6. Installing iMac Intel 24" EMC 2267 Dual Drive: step 6, image 1 of 1
    • Disconnect the microphone cable connector, removing tape as necessary.
    • For the front bezel to sit properly, be sure to tuck the microphone cable and connector into the void next to the camera board.
  7. Installing iMac Intel 24" EMC 2267 Dual Drive, Display Panel: step 7, image 1 of 3 Installing iMac Intel 24" EMC 2267 Dual Drive, Display Panel: step 7, image 2 of 3 Installing iMac Intel 24" EMC 2267 Dual Drive, Display Panel: step 7, image 3 of 3
    • Remove the two 5.3 mm T6 torx screws from the LCD connector.
    • Firmly grasp the pull tab on top of the connector and pull it straight up out of its port.
    • Make sure that you are pulling the tab and not the connector cable.
  8. Installing iMac Intel 24" EMC 2267 Dual Drive: step 8, image 1 of 1
    • Remove the eight T8 Torx screws securing the display panel to the rear case.
    • The iMac shown is a 20" model, but the screw locations should be approximately correct.
  9. Installing iMac Intel 24" EMC 2267 Dual Drive: step 9, image 1 of 3 Installing iMac Intel 24" EMC 2267 Dual Drive: step 9, image 2 of 3 Installing iMac Intel 24" EMC 2267 Dual Drive: step 9, image 3 of 3
    • Place your hands on either side of the bottom of the display panel, and lift it up enough that you can reach the connectors inside.
    • Do not try to remove the display panel completely as it is still connected to the rest of the device.
    • While holding the display panel up with one hand, locate and remove the display thermal sensor cable from its connector.
  10. Installing iMac Intel 24" EMC 2267 Dual Drive: step 10, image 1 of 2 Installing iMac Intel 24" EMC 2267 Dual Drive: step 10, image 2 of 2
    • While still holding the display panel up, use two fingers to firmly push down on the power supply cable connector from its socket.
    • Be very careful not to touch the exposed face of the power supply to avoid electric shock from the many large capacitors attached to the other side of the board.
  11. Installing iMac Intel 24" EMC 2267 Dual Drive: step 11, image 1 of 1
    • Lift and remove the display panel from the device.
  12. Installing iMac Intel 24" EMC 2267 Dual Drive, Optical Drive: step 12, image 1 of 2 Installing iMac Intel 24" EMC 2267 Dual Drive, Optical Drive: step 12, image 2 of 2
    • Peel off the tape holding the optical drive in place.
    • Remove the two 7.1 mm T10 torx screws.
  13. Installing iMac Intel 24" EMC 2267 Dual Drive: step 13, image 1 of 3 Installing iMac Intel 24" EMC 2267 Dual Drive: step 13, image 2 of 3 Installing iMac Intel 24" EMC 2267 Dual Drive: step 13, image 3 of 3
    • Firmly grab the optical drive connector and pull it straight out of the optical drive.
    • Remove the optical drive from the device.
  14. Installing iMac Intel 24" EMC 2267 Dual Drive, Optical Drive: step 14, image 1 of 1
    • Remove the piece of foam tape covering the optical drive thermal sensor.
  15. Installing iMac Intel 24" EMC 2267 Dual Drive: step 15, image 1 of 1
    • To remove the optical drive thermal sensor, use the tip of a spudger to lift the center finger of the thermal sensor bracket while applying slight tension to the thermal sensor cable.
    • If the thermal sensor is stuck to the optical drive, skip to the next step.
  16. Installing iMac Intel 24" EMC 2267 Dual Drive: step 16, image 1 of 1
    • Use the flat end of a spudger to pry the optical drive thermal sensor bracket up off the adhesive securing it to the optical drive.
    • If the adhesive gets dirty or will not stick to your new optical drive, place some double-sided tape under the two semicircular ears of the thermal sensor bracket.
  17. Installing iMac Intel 24" EMC 2267 Dual Drive: step 17, image 1 of 1
    • Use a spudger to remove the small piece of EMI foam from the bottom of the optical drive.
    • Don't forget to transfer this to your new drive.
  18. Installing iMac Intel 24" EMC 2267 Dual Drive: step 18, image 1 of 1
    • Peel the EMI tape off the optical drive.
    • Don't forget to transfer this to your new optical drive.
  19. Installing iMac Intel 24" EMC 2267 Dual Drive: step 19, image 1 of 2 Installing iMac Intel 24" EMC 2267 Dual Drive: step 19, image 2 of 2
    • Remove the two T10 Torx screws from both sides of the optical drive (four screws total).
  20. Installing iMac Intel 24" EMC 2267 Dual Drive: step 20, image 1 of 1
    • Use the tip of a spudger to press each of the optical drive bracket tabs out of their slots on the bottom of the optical drive.
  21. Installing iMac Intel 24" EMC 2267 Dual Drive: step 21, image 1 of 2 Installing iMac Intel 24" EMC 2267 Dual Drive: step 21, image 2 of 2
    • Rotate the optical drive bracket slightly away from the optical drive.
    • Pull the optical drive bracket away from the open end of the optical drive, minding any tabs that may get caught.
    • If you have a disk or anything else stuck inside your optical drive, we have a guide to fix it.
  22. Installing iMac Intel 24" EMC 2267 Dual Drive, Optical Drive Enclosure Faceplate: step 22, image 1 of 1
    • Remove the three 3.0 mm Phillips screws from the optical bay enclosure.
  23. Installing iMac Intel 24" EMC 2267 Dual Drive: step 23, image 1 of 3 Installing iMac Intel 24" EMC 2267 Dual Drive: step 23, image 2 of 3 Installing iMac Intel 24" EMC 2267 Dual Drive: step 23, image 3 of 3
    • Starting from the left edge, gently pull open the optical bay enclosure.
    • Continue to pull open the two halves of the enclosure until they separate.
  24. Installing iMac Intel 24" EMC 2267 Dual Drive: step 24, image 1 of 1
    • Remove the two 3.0 mm Phillips screws securing the faceplate to the optical bay enclosure.
  25. Installing iMac Intel 24" EMC 2267 Dual Drive: step 25, image 1 of 3 Installing iMac Intel 24" EMC 2267 Dual Drive: step 25, image 2 of 3 Installing iMac Intel 24" EMC 2267 Dual Drive: step 25, image 3 of 3
    • Lift the black plastic faceplate out of the optical bay enclosure.
    • You will no longer need the faceplate or the two Phillips screws that held it in place. Set those parts aside if you ever wish to put the faceplate back into the enclosure.
    • Reassemble the optical bay enclosure without the faceplate, reusing the original three 3.0 mm Phillips screws to keep it intact.
  26. Installing iMac Intel 24" EMC 2267 Dual Drive, Dual Hard Drive: step 26, image 1 of 2 Installing iMac Intel 24" EMC 2267 Dual Drive, Dual Hard Drive: step 26, image 2 of 2
    • Remove the plastic positioner from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
  27. Installing iMac Intel 24" EMC 2267 Dual Drive: step 27, image 1 of 3 Installing iMac Intel 24" EMC 2267 Dual Drive: step 27, image 2 of 3 Installing iMac Intel 24" EMC 2267 Dual Drive: step 27, image 3 of 3
    • Make sure that the hard drive connectors are facing down before placing it into the enclosure.
    • Gently place the hard drive into the enclosure's hard drive slot.
    • While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
  28. Installing iMac Intel 24" EMC 2267 Dual Drive: step 28, image 1 of 2 Installing iMac Intel 24" EMC 2267 Dual Drive: step 28, image 2 of 2
    • Once the hard drive is snug, reinsert the plastic positioner while holding the hard drive against the bottom of the enclosure.
    • Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
47 other people completed this guide.
Brittany McCrigler
89,014 Reputation
131 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,817 Guides authored
3 Comments
Many many many thanks, everything went fine with my iMac early 2009 which is now ready for a second life with my kids :)
davbouchard - Reply
Mystery: I have removed and replaced my bezel many times - most recently to repair the vid card. However this time while powering up fine before replacing the bezel - now, once bezel is in place it won’t power on - but I hear a ‘click’ in the lower right corner after pushing the power. But then, if I pull the bezel back about an inch from the top - it starts >Something seems to be ‘shorting’ ?
Albert not Einstein - Reply
Many thanks Brittany and ifixit, no problems encountered and it took me about 2 hours only because I checked and double checked everything I did. iMac early 2009, saved it from the scrap heap for a while longer.
Derek Anson - Reply
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 100
All Time: 66,714
