Installing iMac Intel 24" EMC 2111 Hard Drive Replacement
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Replace the hard drive on your iMac Intel 24" EMC 2111.
  • Add Note x
  • x 48
Upgrade your hard drive for more storage space!
Image #1 Image #2
Add Note Edit Step 1 — Access Door  ¶
  • Loosen the two Phillips screws securing the access door to your iMac.
  • Both screws remain captive within the access door.
  • Remove the access door.
Image #1
Add Note Edit Step 2 — Front Bezel  ¶
  • Remove the following screws along the lower edge of your iMac:
    • Three 6 mm T8 Torx screws
    • One 8 mm T8 Torx screw
Image #1 Image #2
Add Note Edit Step 3  ¶
  • Lay your iMac stand-side down on a flat surface.
  • To lift the front bezel off the iMac, simultaneously:
    • Use your thumbs to press in the RAM arms and hold the iMac down.
    • Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
    • Pull the front bezel up with your index fingers.
  • Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Image #1 Image #2 Image #3
Add Note Edit Step 4  ¶
  • Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
  • The third picture shows the top front bezel brackets and their slots cut into the top edge of the iMac's rear case.
  • Do not completely remove the front bezel, as it is still attached by the camera/microphone cables.
Image #1
Add Note Edit Step 5  ¶
  • If necessary, remove the strip of tape covering the microphone cable connector.
  • The microphone connector is located near the inside of top edge of your iMac.
Add Note Edit Step 6  ¶
  • Disconnect the microphone cable.
  • Disconnect the camera cable by pulling its connector away from the socket on the camera board.
  • The camera cable connector and socket are delicate and easily bent. Remove with caution.
Image #1 Image #2
Add Note Edit Step 7 — Display Assembly  ¶
  • Peel the two highlighted EMI shield tabs off the frame of the LCD.
Image #1
Add Note Edit Step 8  ¶
  • Remove the two T6 Torx screws securing the display data cable to the logic board.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 43 In stock
Spudger
$2.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 13 In stock
Phillips #1 Screwdriver
$4.95 · 5 In stock
Related Products
1 TB 7200 RPM 3.5" Hard Drive
$109.95 · 11 In stock
3 TB 7200 RPM 3.5" Hard Drive
$179.95 · 8 In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 10 In stock
