Installing iMac G5 17" Model A1058 PRAM Battery
  • Add Note x
  • x 5
Use this guide to replace your PRAM battery.
Sections
Image #1
Add Note Edit Step 1 — Rear Panel  ¶
  • Lay the iMac display-side down on a flat surface.
  • Loosen the three Phillips screws securing the rear panel to the iMac.
  • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
Image #1 Image #2 Image #3
Add Note Edit Step 2  ¶
  • Lift the rear panel slightly from the bottom edge of the iMac.
  • Pull the rear panel toward yourself and remove it from the iMac.
Image #1
Add Note Edit Step 3 — AirPort Extreme  ¶
  • Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
  • During reinstallation, insert the AirPort card such that the antenna side is nearest the center of the logic board.
Image #1
Add Note Edit Step 4  ¶
  • Insert the flat end of a spudger between the body of the AirPort card and its antenna connector.
  • Push the spudger away from the AirPort card to disconnect the AirPort antenna.
  • When reassembling your iMac, be sure to insert the AirPort card the way it was before disassembly.
Image #1
Add Note Edit Step 5 — PRAM Battery  ¶
  • Remove the two 5.5 mm T6 Torx screws securing the AirPort bracket to the logic board.
Image #1
Add Note Edit Step 6  ¶
  • Slightly lift the AirPort bracket off the logic board.
  • De-route the AirPort antenna through the slot in the AirPort bracket.
Image #1
Add Note Edit Step 7  ¶
  • Slightly insert the tip of a spudger (or any other small wedge-shaped object) under the PRAM battery directly across from its retaining clip.
  • Do not bend the metal retaining clip up, as it is brittle and will break.
  • Use another spudger to slide the PRAM battery out from under its socket's retaining clip.
Required Tools
Spudger
$2.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 50+ In stock
Phillips #1 Screwdriver
$4.95 · 2 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 13 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
Popular Device Products
1 TB SATA Desktop Hard Drive
$129.95 · 15 In stock
2 TB SATA Desktop Hard Drive
$159.95 · 32 In stock
Arctic Silver Thermal Paste
$8.95 · 50+ In stock
Arctic Silver ArctiClean
$7.95 · 12 In stock
