Installing iBook G4 14" 933 MHz-1.33 GHz Optical Drive
  • Author: iRobot
  • Difficulty: Difficult
  • Add Note x
  • x 19
Upgrade or replace the DVD, combo or SuperDrive.
Image #1
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
Image #1
Add Note Edit Step 2  ¶
  • Lift the battery out of the computer.
Image #1
Add Note Edit Step 3 — Keyboard  ¶
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
  • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Image #1
Add Note Edit Step 4  ¶
  • If the computer has an AirPort card installed, follow the next three steps to remove it.
  • Push the wire clasp away from the AirPort card and toward the display, then rotate up to free it from the RAM shield.
Image #1
Add Note Edit Step 5  ¶
  • Grasp the clear plastic tab on the AirPort card and pull toward the display.
Image #1
Add Note Edit Step 6  ¶
  • Hold the AirPort card in one hand and use your other hand to remove the antenna cable.
Image #1
Add Note Edit Step 7  ¶
  • Remove the four silver Phillips screws that secure the RAM shield.
Image #1
Add Note Edit Step 8  ¶
  • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Flathead 3/32" or 2.5 mm Screwdriver
Coin
$2.95 · 20 In stock
Related Products
iBook G4 12" 24x Combo Drive
$79.95 · 4 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 6 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
