Image #1 Image #2
Add Note Edit Step 9 — Logic Board  ¶
  • Lifting from the headphone jack and power plug, remove the logic board from the front case.
Image #1
Add Note Edit Step 10 — D-pad  ¶
  • Remove the rubber pad from the back of the D-pad.
Image #1
Add Note Edit Step 11  ¶
  • Remove the two 7.0 mm silver Phillips screws from the back of the D-pad.
Image #1 Image #2
Add Note Edit Step 12  ¶
  • The D-pad is secured to its backing by two diagonal clips, shown in red.
  • Use a pair of tweezers and squeeze the clips together to release the D-pad from its backing.
Image #1
Add Note Edit Step 13  ¶
  • Lift the D-pad backing out of its compartment on the front case.
  • The D-pad remains below the front case.
  • The D-pad will fall once its backing is removed. Be sure to support it as you remove the backing.
  • The backing is slotted in its compartment to ensure that it will always be aligned properly.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
T8 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
Popular Products
iPhone 4S Dock Connector
$34.95 · 50+ In stock
iPad Retina Adhesive Strips
$6.95 · 49 In stock
Metal Spudger Set
$7.95 · 41 In stock
Probe and Pick Set
Precision Screw Extractor Set
$19.95 · 50+ In stock
