Installing Xbox 360 S Faceplate
Faceplate replacement.
- Author: Matt Newsom
- Difficulty: Difficult
Make your Xbox 360 S look shiny and new by replacing the outer panels.
Sections
- Top Panel 11 steps
- Hard Drive 2 steps
- Bottom Panel 10 steps
- Left Case 8 steps
- Faceplate 4 steps
Tools
- View:
- Single page
Edit
Step 2
Orient the console so that the words "XBOX 360" on the sides are right-side up, and the faceplate is facing to the left.
Insert a metal spudger between the top vent and the top bezel near the rear of the Xbox.
Rotate the spudger away from the console, prying the edge of the fan vent up until the two plastic clips come free.
Be sure to rotate the spudger far enough so that the plastic clips clear the silver rim of the top bezel.
Edit
Step 6
Orient the console so that the left case is facing toward you and the faceplate is facing toward the right.
Insert a metal spudger through the front-most slit on the left edge of the top bezel and between the bottom edge of the clip and the left case, as described above.
Simultaneously rotate the spudger away from the console and pull up on the top bezel to free the clip.
You will hear a "pop" signifying that the clip cleared its catch.
Edit
Step 9
Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
Edit
Step 15
Orient the Xbox 360 S so that the hard drive port is facing up and the faceplate is facing to the left.
Insert a metal spudger between the black bottom vent and the silver rim of the bottom bezel, in the rear right corner of the vent.
Rotate the spudger away from the console, prying the vent up from the bottom bezel.
Be sure to rotate the spudger far enough so that the clips on the vent are lifted past the silver rim of the bottom bezel.
Edit
Step 18
In the following steps, you will remove the bottom bezel, which is attached to the rest of the console by the six clips shown.
The clips shown in red can be detached by inserting a metal spudger underneath the bottom edge of the clip. Once underneath the bottom edge, simply prying away from the console will free the clip.
Edit
Step 20
Insert a metal spudger through the left middle slit of the bottom bezel, and between the bottom edge of the clip and the left case.
Simultaneously pull the bottom bezel up and rotate the spudger away from the console to free the clip.
In a similar fashion, free the clip at the front of the bottom bezel's left edge.
The entire left side of the bottom bezel should now be free.
Edit
Step 21
Turn the console around so that the faceplate is facing to the right and the right case is facing toward you.
Insert the spudger into the rear-most slit on the right edge of the bottom bezel, and wedge it behind the clip by pushing the spudger down while pushing the tip of the spudger against the right case.
Simultaneously release the clip and pull the bottom bezel up.
This clip is especially hard to remove. Some force will be required to insert the spudger correctly.
Edit
Step 25
Orient the console right-side up, with the faceplate facing toward you.
Locate the two clips connecting the right and left case along the top edge of the console, behind the Wi-Fi card.
While pushing the left and right case away from each other with one hand, pry the clips away from the case with a metal spudger.
Edit
Step 29
Insert the flat edge of a metal spudger between the left and right cases where the warranty sticker used to be.
Pry the left case upwards to form a gap between the two cases, and slide the spudger in toward the left case.
Rotate the spudger upward to release the last clip.
The spudgers holding the top and bottom clips apart may be removed.
Edit
Step 34
Lift the left edge of the faceplate upward to release the last two clips securing the faceplate to the right case.
Detach the faceplate from the rest of the device.
The faceplate is still attached to the console by a thin ribbon cable. Do not attempt to completely remove the faceplate yet.
Edit
Step 35
Using a spudger or fingernail, lift the clear blue tab away from the connector.
Slide the locking tab on the power switch board cable connector toward the top of the console.
The locking tab will only move about 2 mm.
Pull the power switch cable straight out of the connector.
The faceplate is now free of the rest of the console.
Page 1 of 1
