Installing Sony Ericsson s710a Motherboard
User-Contributed Guide
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
This guide shows you how to disconnect the current motherboard and and remove it from the phone.
- Author: Mike
- Time required: 25 minutes
- Difficulty: Moderate
This can be time consuming if this is your first time taking apart the phone. The replacement of the motherboard is very straight forward; however, if a full replacement is necessary it may be more cost effective to replace the phone. Use this guide if you are having hardware issues and find it appropriate to replace the phone's chipset.
- View:
- Single page
Edit
Step 6
Use the plastic opening tool to remove the black plastic cover from the rest of the phone.
It is best to start from the bottom of the phone by the memory card slot.
The cover should pop out of place by the four corners of the phone. There is no need to use excessive force as this may cause the plastic to break.
Page 1 of 2
