Installing Sega Dreamcast Power Supply
User-Contributed Guide
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Use this guide to install a power supply
Instructions on how to replace a defective Sega Dreamcast power supply with a working power supply.
Image #1 Image #2
Add Note Edit Step 1 — Expansion Bay  ¶
  • Verify that the console is disconnected from the AC outlet before you begin.
  • Flip the console over on its back.
  • Take note of your model number, in case replacement parts are needed.
Image #1 Image #2 Image #3
Add Note Edit Step 2  ¶
  • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
Image #1
Add Note Edit Step 3 — Top Cover  ¶
  • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
  • The fourth screw is hidden under the expansion bay if it has not already been removed.
Image #1
Add Note Edit Step 4  ¶
  • Be careful that the internal components do not topple out.
  • Flip the console topside up.
  • Remove the top cover of the chassis by gently lifting the upper portion of the console.
Image #1 Image #2
Add Note Edit Step 5 — Power Supply  ¶
  • Unplug the device from the outlet. If you have just powered off the system, allow a few minutes for the capacitors to discharge before you begin working.
  • Remove the white female pin head by pinching and lifting directly up on the harness.
  • Remove the two Philips #02 screws from the board.
  • Remove the power board. Using both hands, gently lift the power board away from the console without damaging the male pin head
Image #1 Image #2
Add Note Edit Step 6  ¶
  • Remove the unit. Carefully remove the power board from the console by lightly grasping the board by the edge and lifting directly upward.
  • Remove the two 10mm #02 Philips screws to detach the switch module from the console.
  • Purchase a replacement power board.
Required Tools
Phillips #1 Screwdriver
$4.95 · 3 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 15 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
Popular Products
iPad 2 Front Panel
$94.95 · 50+ In stock
iPhone 4S Display Assembly
$94.95 · 21 In stock
iPhone 4S Dock Connector
$34.95 · 50+ In stock
1.5" Thin Putty Knife
$6.95 · 8 In stock
Anti-Static Mat
$24.95 · 50+ In stock
