Installing Sansa e260R Memory Board
Action Shots
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
User-Contributed Guide
Sections
Image #1
Add Note Edit Step 1 — Rear Case  ¶
  • Before disassembling the device, make sure it is powered off.
  • Remove the four 1.5mm screws on the back of the device.
Image #1
Add Note Edit Step 2  ¶
  • Using a plastic opening tool, lift the metal backing from the front of the device.
Image #1
Add Note Edit Step 3  ¶
  • Pull the rear panel off of the Sansa e260R.
Image #1
Add Note Edit Step 4 — Battery  ¶
  • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
Image #1
Add Note Edit Step 5 — Front Panel  ¶
  • Remove the four 1.5mm screws on the inner casing of the device.
  • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
Image #1
Add Note Edit Step 6  ¶
  • Flip the device so that the front is facing you.
  • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
Image #1 Image #2
Add Note Edit Step 7  ¶
  • Pull the front cover away from the rest of the device.
Image #1 Image #2
Add Note Edit Step 8 — Memory Board  ¶
  • Near the charging port, pull the case away from the motherboard to create clearance to remove the motherboard.
  • Use the spudger to push the motherboard in and pop the metal edge of the charging port up and inside the plastic case.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Plastic Opening Tools
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 13 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
Popular Products
iPhone 4S Rear Glass Panel
$44.95 · 50+ In stock
iPhone 4S Dock Connector
$34.95 · 50+ In stock
Anti-Static Mat
$24.95 · 50+ In stock
Probe and Pick Set
$6.95 · 50+ In stock
