Installing Samsung SCH-3500 Antenna
Grammar Police
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Needs Better Images
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
User-Contributed Guide
Antenna Installation is also straightforward, requiring no tools, but does require prior battery removal knowledge. During antenna installation, make sure to remove both the antenna and guide tube for completion.
Sections
Image #1 Image #2
  • Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb.
Image #1
Add Note Edit Step 2  ¶
  • Slide battery toward bottom of the phone, ~1/4 inch, to clear the hooks that keep it secured to the back of the phone.
Image #1
Add Note Edit Step 3  ¶
  • Lift battery away from phone case.
  • The battery is now removed from the device. Congratulations.
Image #1 Image #2
Add Note Edit Step 4 — Antenna  ¶
  • Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone.
Image #1
Add Note Edit Step 5  ¶
  • When unscrewed, pull the antenna straight up and out.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • Pull guide tube free from its retaining ring and slide it out the top, like the antenna (optional).
  • The antenna and its guide tube are now removed from the phone. Congratulations.
Popular Products
iPad 2 Front Panel
$94.95 · 2 In stock
iPhone 5 Liberation Kit
$9.95 · 22 In stock
T8 Torx Security Bit Screwdriver
$6.95 · 42 In stock
Screw Extracting Pliers
$29.95 · 50+ In stock
