Samsung Captivate Speaker Replacement
  1. Samsung Captivate Speaker Replacement, Battery: step 1, image 1 of 1
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate Speaker Replacement: step 2, image 1 of 1
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate Speaker Replacement: step 3, image 1 of 1
    • Replace the old battery with the new one.
  4. Samsung Captivate Speaker Replacement, Rear Case: step 4, image 1 of 1
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate Speaker Replacement: step 5, image 1 of 1
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate Speaker Replacement: step 6, image 1 of 3 Samsung Captivate Speaker Replacement: step 6, image 2 of 3 Samsung Captivate Speaker Replacement: step 6, image 3 of 3
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate Speaker Replacement: step 7, image 1 of 1
    • Separate the rear case from the phone.
  8. Samsung Captivate Speaker Replacement, Speaker: step 8, image 1 of 1
    • Use the Phillips 00 screwdriver to remove the single screw holding the speaker assembly to the LCD.
  9. Samsung Captivate Speaker Replacement: step 9, image 1 of 2 Samsung Captivate Speaker Replacement: step 9, image 2 of 2
    • Use the plastic opening tool to lift the bottom tab of the plastic ribbon cable connector. Be careful not to use excessive force, you are only releasing the tab that holds the cable in.
    • Pull out the ribbon cable.
    • Use a spudger or plastic opening tool to lift up the speaker, and use your hands to remove it.
11 other people completed this guide.
Drew Bentz
565 Reputation
5 Guides authored
Cal Poly, Team 20-25, Maness Fall 2011 Member of Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 Members
9 Guides authored
One Comment
It was clear enough to follow, don't know why it got the incorrect text caveat.
I gotta get one of those spudger sets.
Also it did not say where to get the actual replacement speaker.
G Trieste - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 8,740
