Installing PowerBook G4 Aluminum 12" 1-1.5 GHz Airport Extreme Card
  • Add Note x
  • x 16
Install an Airport Extreme 802.11g card internally.
Image #1
  • Use a coin to turn the battery locking screw 90 degrees to the right.
  • Lift the battery out of the computer.
Image #1
Add Note Edit Step 2 — Airport Extreme Card  ¶
  • Flip down the door on the right side of the battery compartment.
Image #1
Add Note Edit Step 3  ¶
  • Use a spudger or flathead screwdriver to disconnect the Airport antenna from the card.
Image #1
Add Note Edit Step 4  ¶
  • Grasp the plastic tab and pull the card out all the way.
Required Tools
Spudger
$2.95 · 50+ In stock
Coin
$2.95 · 20 In stock
Related Products
$29.95 · 50+ In stock
