View profile
Teams
Order History
Logout
« Previous
Page 3 of 3
Lift the clutch cover off by rotating it up and then toward you.
Disconnect the orange display data cable on the left side of the computer. Grasp the cable near the connector and pull directly up.
Disconnect the orange display inverter cable on the right side of the computer. Grasp the cable near the connector and pull directly up.
Make sure that both cables are free from the plastic casing before proceeding to the next step.
Turn the laptop around so that its back faces you.
Open the port door located at the back of the laptop.
Remove the four black T8 Torx screws.
Turn the laptop back around so that the screen faces you.
Adjust the display so that it is in a vertical position.
Hold the display on both sides and pull directly up until its hinges are free of their mounts
Your laptop should look like this.
Next » « Previous
$4.95 · 50+ In stock
$6.95 · 50+ In stock
$7.95 · 50+ In stock
$2.95 · 50+ In stock
$29.95 · 50+ In stock
$29.95 · 26 In stock
$39.95 · 39 In stock
$24.95 · 48 In stock
$24.95 · 18 In stock
$99.95 · 1 In stock
1024
