View profile
Teams
Order History
Logout
« Previous
Page 2 of 2
With the help of a spudger, gently pry off and remove the battery cable retainer on the back casing assembly.
The easiest access to the battery cable retainer is where the battery cable comes out.
Using a Phillips #00 screwdriver, remove the two 5.0mm blue battery case screws.
Remove the plastic battery retaining bar.
Using your finger or a spudger, lift the battery out and remove it.
Guide the battery wires through the hole in the back casing as you remove the battery.
Slide the spuder between the right speaker and the rear casing.
Using a spudger, gently peel up the right speaker from the light adhesive connecting it to casing.
Remove the right speaker.
Slide the spudger between the left speaker and the rear casing.
Using a spudger, gently peel up the left speaker from the light adhesive connecting it to casing.
Remove the left speaker.
The rear panel remains.
Next » « Previous
$2.95 · 50+ In stock
$4.95 · 50+ In stock
$29.95 · 50+ In stock
$29.95 · 17 In stock
$39.95 · 38 In stock
$24.95 · 48 In stock
$24.95 · 16 In stock
$109.95 · 7 In stock
$94.95 · 29 In stock
$14.95 · 50+ In stock
$9.95 · 23 In stock
1024
