Image #1
Add Note Edit Step 9  ¶
  • Lift the power supply upward from its left edge as viewed from the front of the PS3.
Image #1 Image #2
Add Note Edit Step 10  ¶
  • Continue to lift the left edge of the power supply until it lifts off the two metal posts shown in the second picture.
  • Remove the power supply from the PS3, minding any cables that may get caught.
Image #1 Image #2
Add Note Edit Step 11 — Blu-ray Disc Drive  ¶
  • If present, remove the pieces of tape securing the cables to the body of the Blu-ray drive.
Image #1
Add Note Edit Step 12  ¶
  • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
  • Be sure you are prying up on the movable retaining flap, not the socket itself.
Image #1
Add Note Edit Step 13  ¶
  • Pull the Blu-ray ribbon cable straight up and out of its socket.
Image #1
Add Note Edit Step 14  ¶
  • Pull the Blu-ray power cable straight up to lift its connector out of the socket on the Blu-ray drive.
Image #1
Add Note Edit Step 15  ¶
  • Remove the single 9.5 mm Phillips screw securing the Blu-ray drive to the lower case.
Image #1 Image #2
Add Note Edit Step 16  ¶
  • Lift the Blu-ray drive slightly by its right edge to dislodge the control board from its housing.
  • Remove the Blu-ray drive from the PS3.
  • After you reinstall the Blu-ray drive, be sure the control board is firmly seated in the lower case before proceeding.
  • If replacing the Blu-ray drive with a new drive, swap the circuit board from your old drive into the new drive.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #1 Screwdriver
$4.95 · 27 In stock
Metal Spudger
T8 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 6 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
Popular Device Products
500 GB 7200 RPM SATA Hard Drive (New)
$109.95 · 12 In stock
Arctic Silver Thermal Paste
$8.95 · 50+ In stock
Arctic Silver ArctiClean
$7.95 · 10 In stock
