Installing PlayStation 3 Control Board
Replace the electronic portion of your PS3's eject and I/O buttons.
  • Add Note x
  • x 6
Use this guide to replace a broken control board.
Image #1 Image #2
Add Note Edit Step 1 — Smart Plate  ¶
  • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
Image #1
Add Note Edit Step 2  ¶
  • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
Image #1 Image #2 Image #3
Add Note Edit Step 3  ¶
  • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
Image #1
Add Note Edit Step 4  ¶
  • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
Image #1
Add Note Edit Step 5 — Top Cover  ¶
  • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
Image #1
Add Note Edit Step 6  ¶
  • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
  • Remove the top cover.
Image #1 Image #2
Add Note Edit Step 7 — Control Board  ¶
  • Use your fingernail to flip up the retaining flap on the control board ribbon cable socket.
  • Be sure you are prying up on the retaining flap, not the socket itself.
  • Pull the control board ribbon cable out of its socket.
Image #1
Add Note Edit Step 8  ¶
  • Remove the two 12 mm Phillips screws securing the control board to the lower case.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #1 Screwdriver
$4.95 · 5 In stock
T10 Torx Security Bit Screwdriver
$6.95 · 29 In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 10 In stock
