OLPC XO-4 Touch Screen Replacement
  1. OLPC XO-4 Touch Screen Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop upside-down, with the handle facing away from you.
  2. OLPC XO-4 Touch Screen Replacement: step 2, image 1 of 2 OLPC XO-4 Touch Screen Replacement: step 2, image 2 of 2
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. OLPC XO-4 Touch Screen Replacement: step 3, image 1 of 2 OLPC XO-4 Touch Screen Replacement: step 3, image 2 of 2
    • Lift up on the middle of the battery to remove it from the device.
  4. OLPC XO-4 Touch Screen Replacement, Screen Frame: step 4, image 1 of 3 OLPC XO-4 Touch Screen Replacement, Screen Frame: step 4, image 2 of 3 OLPC XO-4 Touch Screen Replacement, Screen Frame: step 4, image 3 of 3
    • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
    • Rotate the screen 180° and remove the other two screws.
    • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
  5. OLPC XO-4 Touch Screen Replacement: step 5, image 1 of 3 OLPC XO-4 Touch Screen Replacement: step 5, image 2 of 3 OLPC XO-4 Touch Screen Replacement: step 5, image 3 of 3
    • Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
    • Repeat the step above for the panel on the other side.
  6. OLPC XO-4 Touch Screen Replacement: step 6, image 1 of 1
    • Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
    • Gently lift up the lower part of the frame and pull it down to free the screen frame.
  7. OLPC XO-4 Touch Screen Replacement: step 7, image 1 of 2 OLPC XO-4 Touch Screen Replacement: step 7, image 2 of 2
    • Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
  8. OLPC XO-4 Touch Screen Replacement, Screen: step 8, image 1 of 1
    • Remove the four 7.62mm screws using a Phillips #1 screwdriver.
  9. OLPC XO-4 Touch Screen Replacement: step 9, image 1 of 2 OLPC XO-4 Touch Screen Replacement: step 9, image 2 of 2
    • Be careful not to pull the screen out too far. There are two ribbon cables attached to the screen, and they can easily break.
    • Carefully lift the screen out.
  10. OLPC XO-4 Touch Screen Replacement: step 10, image 1 of 3 OLPC XO-4 Touch Screen Replacement: step 10, image 2 of 3 OLPC XO-4 Touch Screen Replacement: step 10, image 3 of 3
    • Notice that the laptop in this picture has been turned 180° with the antennas now below the screen.
    • For each ribbon cable, lift up the black connector and gently pull the ribbon cables out by the plastic tabs.
  11. OLPC XO-4 Touch Screen Replacement: step 11, image 1 of 1
    • Remove the screen from the laptop.
2 other people completed this guide.
Zach Yasuda
173 Reputation
2 Guides authored
Cal Poly, Team 3-29, Amido Winter 2013 Member of Cal Poly, Team 3-29, Amido Winter 2013
CPSU-AMIDO-W13S3G29
4 Members
20 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 14
All Time: 1,613
