Installing Nokia 2128i Internal Clock Battery
User-Contributed Guide
Inconsistent Images
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
This guide will show how to access and remove the internal clock battery for your phone.
  • Author: Curtis Lutje
  • Time required: 5 to 10 minutes
  • Difficulty: Moderate
The time on your phone is always wrong, making you arrive at the wrong time. Switch out the internal clock battery and always be on time.
Image #1 Image #2 Image #3
  • Be sure cell phone is off before you begin to disassemble the phone.
  • Press the button on the bottom of the back of the cell phone.
  • Slide rear panel down and remove it.
Add Note Edit Step 2  ¶
  • Using your fingernail, pry the back of the battery upwards and pull out.
Add Note Edit Step 3 — Faceplate  ¶
  • Insert the plastic opening tool under the faceplate.
  • Separate the faceplate from main body by twisting the prying tool with some force.
  • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
Add Note Edit Step 4 — Keypad  ¶
  • With the faceplate removed, simply peel off rubber key pad and remove.
Add Note Edit Step 5 — Motherboard Assembly  ¶
  • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
Add Note Edit Step 6  ¶
  • After removing screws, lift the motherboard assembly straight off the cell phone body.
Image #1 Image #2
Add Note Edit Step 7 — Internal Clock Battery  ¶
  • With the logic board completely removed, gently pry out the internal clock battery from its housing.
Required Tools
T6 Torx Screwdriver
$4.95 · 50+ In stock
Plastic Opening Tools
$2.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 26 In stock
Inspection Scope
$39.95 · 39 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 18 In stock
Popular Products
Unibody Laptop Dual Drive
$39.95 · 50+ In stock
iPhone 4S Rear Glass Panel
$44.95 · 50+ In stock
Helping Hands
$8.95 · 50+ In stock
Mac Mini Logic Board Removal Tool
$4.95 · 38 In stock
