Nintendo Wii Bluetooth Board Replacement
  1. Nintendo Wii Bluetooth Board Replacement, Faceplate: step 1, image 1 of 2 Nintendo Wii Bluetooth Board Replacement, Faceplate: step 1, image 2 of 2
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Nintendo Wii Bluetooth Board Replacement: step 2, image 1 of 1
    • Remove the two 8.3 mm Tri-Point screws hidden under the covers you just removed.
  3. Nintendo Wii Bluetooth Board Replacement: step 3, image 1 of 1
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Nintendo Wii Bluetooth Board Replacement: step 4, image 1 of 1
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
  5. Nintendo Wii Bluetooth Board Replacement: step 5, image 1 of 1
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
  6. Nintendo Wii Bluetooth Board Replacement: step 6, image 1 of 2 Nintendo Wii Bluetooth Board Replacement: step 6, image 2 of 2
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
  7. Nintendo Wii Bluetooth Board Replacement, Outer Case: step 7, image 1 of 3 Nintendo Wii Bluetooth Board Replacement, Outer Case: step 7, image 2 of 3 Nintendo Wii Bluetooth Board Replacement, Outer Case: step 7, image 3 of 3
    • Open the controller port cover until it is perpendicular to the black controller port bezel.
    • Pull the controller port cover straight up to release it from the outer case.
    • Repeat this procedure for the memory card port cover.
  8. Nintendo Wii Bluetooth Board Replacement: step 8, image 1 of 2 Nintendo Wii Bluetooth Board Replacement: step 8, image 2 of 2
    • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
    • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
  9. Nintendo Wii Bluetooth Board Replacement: step 9, image 1 of 1
    • Remove the two 5 mm Phillips screws above the controller ports.
  10. Nintendo Wii Bluetooth Board Replacement: step 10, image 1 of 1
    • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
  11. Nintendo Wii Bluetooth Board Replacement: step 11, image 1 of 1
    • Remove the following screws:
    • Two 5 mm Phillips screws
    • One 8.2 mm Tri-Point screw
  12. Nintendo Wii Bluetooth Board Replacement: step 12, image 1 of 1
    • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
  13. Nintendo Wii Bluetooth Board Replacement: step 13, image 1 of 1
    • Remove the two 8.2 mm Tri-Point screws hidden under the feet you just removed.
    • You may use a 4 mm hex driver to extend your bit into the recesses and reach the screws.
  14. Nintendo Wii Bluetooth Board Replacement: step 14, image 1 of 1
    • Lift the outer case straight up off the body of the Wii.
  15. Nintendo Wii Bluetooth Board Replacement, DVD Drive: step 15, image 1 of 2 Nintendo Wii Bluetooth Board Replacement, DVD Drive: step 15, image 2 of 2
    • Remove the small Phillips screw securing the battery door to the bottom panel.
    • This screw is captive to the battery door.
    • Pull the battery door out of the Wii.
    • The system time will be reset once you remove the battery door.
    • This is a good time to change the CR2032 battery if it hasn't been changed recently.
  16. Nintendo Wii Bluetooth Board Replacement: step 16, image 1 of 1
    • Remove the 8.2 mm Tri-Point screw that was hidden beneath the battery door.
  17. Nintendo Wii Bluetooth Board Replacement: step 17, image 1 of 1
    • Remove the two 8.2 mm Tri-Point screws securing the DVD drive shield near the controller ports.
  18. Nintendo Wii Bluetooth Board Replacement: step 18, image 1 of 1
    • Lift the DVD drive shield upward and remove it from the Wii.
  19. Nintendo Wii Bluetooth Board Replacement: step 19, image 1 of 1
    • Remove the four 9 mm #1 Phillips screws securing the DVD drive to the bottom panel.
  20. Nintendo Wii Bluetooth Board Replacement: step 20, image 1 of 1
    • Lift the side of the DVD drive opposite the controller ports enough to access the cables on its bottom face.
    • Carefully pull the DVD drive power cable out from under the plastic shroud near the heat sink.
  21. Nintendo Wii Bluetooth Board Replacement: step 21, image 1 of 1
    • Pull the DVD drive power cable away from its socket on the DVD drive.
  22. Nintendo Wii Bluetooth Board Replacement: step 22, image 1 of 2 Nintendo Wii Bluetooth Board Replacement: step 22, image 2 of 2
    • Use your fingernail to flip up the retaining flap on the DVD drive ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the DVD drive ribbon cable out of its socket.
    • Remove the DVD drive from the Wii.
  23. Nintendo Wii Bluetooth Board Replacement, Motherboard Cover: step 23, image 1 of 1
    • Use a pair of tweezers to lift the fan connector up and out of its socket on the logic board.
    • Be sure your tweezers are clamped down on the fan connector, not the socket on the motherboard.
  24. Nintendo Wii Bluetooth Board Replacement: step 24, image 1 of 2 Nintendo Wii Bluetooth Board Replacement: step 24, image 2 of 2
    • Remove the two 10 mm Phillips screws securing the fan to the fan shroud.
    • Remove the fan from the Wii.
  25. Nintendo Wii Bluetooth Board Replacement: step 25, image 1 of 2 Nintendo Wii Bluetooth Board Replacement: step 25, image 2 of 2
    • Use the tip of a spudger or another fine-pointed tool to carefully pry one of the black plastic retaining fingers attached to the fan shroud away from the Wi-Fi antenna board.
    • Lift the Wi-Fi antenna out of the fan shroud.
  26. Nintendo Wii Bluetooth Board Replacement: step 26, image 1 of 1
    • Remove the single 10 mm Phillips screw securing the second Wi-Fi antenna to the top of the fan shroud.
  27. Nintendo Wii Bluetooth Board Replacement: step 27, image 1 of 1
    • Remove the two pieces of tape securing the second Wi-Fi antenna cable to the plastic bracket near the heat sink.
  28. Nintendo Wii Bluetooth Board Replacement: step 28, image 1 of 1
    • Carefully de-route both antennas from the frame of the Wii and lay them aside.
  29. Nintendo Wii Bluetooth Board Replacement: step 29, image 1 of 2 Nintendo Wii Bluetooth Board Replacement: step 29, image 2 of 2
    • Remove the three 10 mm Phillips screws securing the fan shroud to the Wii.
    • Lift the fan shroud off the heat sink and remove it from the Wii.
  30. Nintendo Wii Bluetooth Board Replacement: step 30, image 1 of 3 Nintendo Wii Bluetooth Board Replacement: step 30, image 2 of 3 Nintendo Wii Bluetooth Board Replacement: step 30, image 3 of 3
    • Remove the following six screws securing the EMI fingers to the bottom panel:
    • Four 7 mm Phillips screws
    • Two 11.3 mm Phillips screws
    • Remove both sets of EMI fingers from the Wii.
  31. Nintendo Wii Bluetooth Board Replacement: step 31, image 1 of 2 Nintendo Wii Bluetooth Board Replacement: step 31, image 2 of 2
    • Remove the following three screws:
    • One 7 mm Phillips screw
    • Two 10 mm Phillips screws
    • Lift the bracket out of the Wii.
  32. Nintendo Wii Bluetooth Board Replacement: step 32, image 1 of 3 Nintendo Wii Bluetooth Board Replacement: step 32, image 2 of 3 Nintendo Wii Bluetooth Board Replacement: step 32, image 3 of 3
    • Remove the three 10 mm Phillips screws securing the black bracket to the bottom panel near the front of the Wii.
    • Slightly lift the bracket and use your other hand to pull the retaining clip away from where the Wi-Fi antennas enter the motherboard sheild.
    • Remove the bracket from the Wii.
    • Be sure not to lose the small square nut loosely held by the black plastic bracket.
  33. Nintendo Wii Bluetooth Board Replacement: step 33, image 1 of 1
    • Remove the nine remaining 7 mm Phillips screws securing the motherboard cover to the bottom panel.
  34. Nintendo Wii Bluetooth Board Replacement: step 34, image 1 of 1
    • Carefully lift the motherboard cover off the motherboard, minding any cables that may get caught.
    • On some models, a thermal pad for the wireless chip is attached to the underside of the motherboard cover. Be sure to replace it when reassembling.
  35. Nintendo Wii Bluetooth Board Replacement, Bluetooth Board: step 35, image 1 of 3 Nintendo Wii Bluetooth Board Replacement, Bluetooth Board: step 35, image 2 of 3 Nintendo Wii Bluetooth Board Replacement, Bluetooth Board: step 35, image 3 of 3
    • Use the flat end of a spudger or your fingertips to lift up the end of the Bluetooth board nearest the center of the motherboard.
    • Carefully peel the front edge of the Bluetooth board off the EMI foam attached to the motherboard.
    • Remove the Bluetooth board.
44 other people completed this guide.
8 Comments
I just used this guide to fix my Wii's bluetooth. Fantastic step by step guide, Wii responds to wiimote now. Thanks for this awesome repair guide. It took full 2 hours to complete the job.
Mitr - Reply
I was terrified about trying to fix the Wii myself. These instructions were marvelously accurate and easy to follow. In two hours and for about $15 I was able to repair the Wii and go back to my favorite games. Thanks! :)
Danielle - Reply
Fantastic write up. My wiimote sync'd right up.
Charlie Kilo - Reply
A flawless guide. All worked well. I replugged the bluetooth unit and then my Nintendo worked again perfectly.
Marc - Reply
Wow, what an amazing guide. Thank you very, very much. I just used this guide to refit my loose Bluetooth board. Now my Wii is working perfectly again. Thank you, thank you, thank you.
Elzanne - Reply
Past 24 Hours: 18
Past 7 Days: 104
Past 30 Days: 442
All Time: 70,690
