Installing Nintendo DSi XL Rear Bezel
Rear bezel replacement.
Be the envy of onlooking gamers with a shiny new rear bezel on your DSi XL.
Image #1 Image #2 Image #3
Add Note Edit Step 1 — Rear Bezel  ¶
  • Use a push pin to remove the four plastic screw covers on the front bezel.
Image #1
Add Note Edit Step 2  ¶
  • Remove four Phillips screws securing the front bezel to the rear bezel.
Image #1 Image #2
Add Note Edit Step 3  ¶
  • Using two hands, gently slide the rear bezel upwards.
  • The rear bezel will move only about 2 mm.
Image #1 Image #2
Add Note Edit Step 4  ¶
  • Insert a spudger into the gap between the front and rear bezel
  • Rotate the spudger away from the DSi XL, prying the two bezels apart.
Image #1
Add Note Edit Step 5  ¶
  • In the same manner as described above, continue prying along the top edge of the front and rear bezels.
Image #1
Add Note Edit Step 6  ¶
  • Separate the rear bezel from the front bezel.
  • Do not attempt to completely remove the rear bezel yet. It is still attached to the front bezel by the rear-facing camera.
Image #1
Add Note Edit Step 7  ¶
  • Use the flat end of a spudger to pry the rear camera off the rear bezel.
  • Remove the rear bezel.
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 31 In stock
Inspection Scope
$39.95 · 40 In stock
Frictionless Ratchet
$24.95 · 49 In stock
Portable Anti-Static Mat
$24.95 · 19 In stock
