Installing Nintendo DSi XL Power Button
DSi XL Power Button replacement.
Regain power over your DSi XL by replacing or cleaning a faulty or sticky power button.
Image #1 Image #2
  • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
  • Lift the battery cover off the back of the DSi XL.
Image #1
Add Note Edit Step 2  ¶
  • Lift the battery from the DSi XL.
Image #1 Image #2 Image #3
Add Note Edit Step 3 — Lower Case  ¶
  • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
Image #1
Add Note Edit Step 4  ¶
  • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
Add Note Edit Step 5  ¶
  • Turn the DSi XL over, and open the display.
  • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
  • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • Close the display and turn the DSi XL over.
  • Lift the lower case from the front edge.
  • Rotate the lower case away from the DSi.
  • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
Image #1 Image #2
Add Note Edit Step 7  ¶
  • Using a spudger, pry the SD card/right shoulder button connector off its socket.
  • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
Image #1 Image #2
Add Note Edit Step 8 — Power Board  ¶
  • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-pad/power button cable.
  • With the pointed end of the spudger, pull the D-pad/power button cable from its connector on the motherboard.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 15 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
