Installing Nintendo 3DS Lower Display Assembly
Lower display assembly removal
If both the LCD and touchscreen of your lower display are bad, then you'll have to replace the whole thing.
Image #1
Add Note Edit Step 1 — Back Cover  ¶
  • Unscrew the four Phillips screws along the top of the back cover.
  • The screws are held in place by locking washers, and will not come out of the back cover.
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Hold the device in one hand and turn it over.
  • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
  • Flip the 3DS over again so that the back cover is facing up.
  • Pull the back cover up and away from the rest of the device to remove it.
Image #1 Image #2 Image #3
Add Note Edit Step 3 — Battery  ¶
  • Insert a plastic opening tool into the notch in the lower case above the battery.
  • Pry the battery up with the plastic opening tool.
  • Grab the top edge of the battery and lift it out of the lower case.
Image #1
Add Note Edit Step 4 — Lower Case  ¶
  • Remove the nine 6.3 mm black Phillips screws from the lower case.
  • Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
Add Note Edit Step 5  ¶
  • Lift the bottom edge of the lower case off the rest of the 3DS.
  • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
  • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
  • Remove the lower case from the device.
Image #1
Add Note Edit Step 6 — Circle Pad Joystick  ¶
  • Remove the two 7.7 mm Phillips screws securing the back of the Circle Pad to the motherboard.
Add Note Edit Step 7  ¶
  • Use the flat end of a spudger to pry the back of the Circle Pad off the motherboard.
  • Lift the Circle Pad joystick off the motherboard and lay it on its back so that the ribbon cable connector is accessible.
Add Note Edit Step 8  ¶
  • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Circle Pad ribbon cable ZIF socket.
  • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  • Lift the Circle Pad joystick off the motherboard.
Image #1 Image #2
Add Note Edit Step 9  ¶
  • To decrease the chance of losing it during repairs, you may want to remove the two thin pads underneath the Circle Pad joystick.
  • Use a spudger or screwdriver to lift the pads up and remove them from the device.
Image #1
Add Note Edit Step 10 — SD Board  ¶
  • Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
Image #1 Image #2
Add Note Edit Step 11  ¶
  • Use the flat end of a spudger to pry the SD board ribbon cable connector off its socket on the motherboard.
Add Note Edit Step 12  ¶
  • Insert the flat end of a spudger between the SD board and the motherboard.
  • Run the spudger along the sides of the SD board to free it from the adhesive pad holding it in place.
  • Once completely freed, lift the SD board straight off the motherboard.
Image #1 Image #2
Add Note Edit Step 13 — Wi-Fi Board  ¶
  • Slide the flat end of a spudger under the corner of the Wi-Fi board, and lift it away from the motherboard.
  • The Wi-Fi antenna cable is still connected to the Wi-Fi board, so you cannot completely remove the Wi-Fi board yet.
Add Note Edit Step 14  ¶
  • Lift the Wi-Fi board off the motherboard and rotate it so that the bottom side is facing up.
  • Use the flat end of a spudger to pry the Wi-Fi antenna cable connector off its socket on the Wi-Fi board.
  • Remove the Wi-Fi board from the device.
Image #1 Image #2
Add Note Edit Step 15 — Motherboard Assembly  ¶
  • Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
  • Pull the microphone straight up out of the upper case.
Add Note Edit Step 16  ¶
  • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the speaker assembly ribbon cable ZIF socket.
  • Disconnect the speaker assembly ribbon cable with a pair of tweezers.
Image #1 Image #2
Add Note Edit Step 17  ¶
  • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the camera ribbon cable ZIF socket.
Add Note Edit Step 18  ¶
  • Remove seven Phillips screws securing the motherboard to the upper case:
    • Four 2.5 mm gold screws
    • Two 3.5 mm black screws
    • One 2.5 mm silver screw
  • Lift the side of the motherboard that sits along the bottom edge of the 3DS.
Add Note Edit Step 19  ¶
  • Continue lifting the motherboard assembly and rotate it until it is resting next to the rest of the device.
  • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the LCD ribbon cable ZIF socket.
Image #1
Add Note Edit Step 20  ¶
  • Remove the motherboard assembly from the rest of the device.
Add Note Edit Step 21 — Lower Display Assembly  ¶
  • Set the motherboard assembly down so that the lower LCD is side-by-side with the motherboard.
  • Use the tip of a spudger or your fingers to peel back the white tape covering the touchscreen ribbon cable connector.
Image #1 Image #2
Add Note Edit Step 22  ¶
  • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the touchscreen ribbon cable ZIF socket.
Add Note Edit Step 23  ¶
  • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the lower LCD power ribbon cable ZIF socket.
  • Pull the ribbon cable out of the connector with a pair of tweezers.
  • Grasp the ribbon cable as close to the connector as possible with the tweezers to avoid tearing it.
Image #1 Image #2
Add Note Edit Step 24  ¶
  • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the lower LCD data ribbon cable ZIF socket.
Image #1
Add Note Edit Step 25  ¶
  • Grasp the lower display assembly and pull it directly away from the motherboard.
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Plastic Opening Tools
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 15 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
Popular Products
iPad 2 Adhesive Strips
$6.95 · 50+ In stock
iPhone 4S Replacement Battery
iPhone 4S Dock Connector
$34.95 · 50+ In stock
iPad 3rd Gen Front Panel Assembly
$134.95 · 50+ In stock
iPhone 3G and 3GS Power Button
$4.95 · 24 In stock
