Image #1 Image #2 Image #3
Add Note Edit Step 33  ¶
  • Use the flat end of a spudger or your fingernail to flip up the retaining flaps on the parallax barrier ribbon cable ZIF sockets.
  • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  • Use a pair of metal tweezers to disconnect the two ribbon cables.
Add Note Edit Step 34  ¶
  • Use the flat end of a spudger to pry the left and right speakers out of their places in the upper display bezel.
  • Pry the camera status LED out of the upper display bezel with the tip of a spudger.
Image #1
Add Note Edit Step 35  ¶
  • Remove the speaker assembly from the rest of the display assembly.
Image #1 Image #2
Add Note Edit Step 36 — Cameras  ¶
  • Gently roll the upper LCD ribbon cable and camera ribbon cable together and insert them into the hinge opening.
Add Note Edit Step 37  ¶
  • Use a pair of metal tweezers to remove the black metal hinge ring from the upper display bezel.
  • Carefully pull the camera and upper LCD ribbon cables through their hole in the upper display bezel.
Image #1 Image #2
Add Note Edit Step 38  ¶
  • Peel the camera ribbon cable off the back of the upper LCD.
  • The ribbon cable is held to the back of the LCD housing by an adhesive, so pull on it gently to avoid tearing the ribbon cable.
  • Remove the camera ribbon cable assembly.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Heat Gun
$24.95 · 19 In stock
Plastic Opening Tools
Probe and Pick Set
$6.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 6 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
Popular Products
Flathead 3/32" or 2.5 mm Screwdriver
Soldering Station
$24.95 · 20 In stock
T5 Torx Screwdriver
T10 Torx Security Bit Screwdriver
$6.95 · 49 In stock
iSesamo Opening Tool
$9.95 · 50+ In stock
