Installing Motorola Slvr L7 Front Panel
Grammar Police
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Incorrect Tools
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
User-Contributed Guide
Step-by-Step process of installing HTC Front Panel
Image #1
Add Note Edit Step 1 — Front Panel  ¶
  • Push down on the black tab located at the top center of the Motorola phone
Image #1
Add Note Edit Step 2  ¶
  • Remove the battery by pulling the battery from the top center.
Image #1
Add Note Edit Step 3  ¶
  • Remove the four T6 2 mm TX Torx screws
Image #1 Image #2
Add Note Edit Step 4  ¶
  • Insert the flat end of a plastic opening tool and pry the metal cover up off the phone.
Image #1 Image #2
Add Note Edit Step 5  ¶
  • Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a plastic opening tool.
Image #1
Add Note Edit Step 6  ¶
  • Use a plastic opening tool to pry the antenna cable connectors from its respective socket on the motherboard.
  • De-route the antenna cable by pulling it out.
Image #1
Add Note Edit Step 7  ¶
  • Use a spudger to lift and remove the black plastic screw cover at the bottom of the phone near the speaker
  • The cover is attached by adhesive, so some force may be required.
Image #1 Image #2
Add Note Edit Step 8  ¶
  • Insert the flat end of a spudger and pry the frame off the phone.
  • The frame is attached by adhesive, so some force may be required
Required Tools
Spudger
$2.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 50+ In stock
Phillips #00 Screwdriver
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 24 In stock
Inspection Scope
$39.95 · 39 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 18 In stock
Popular Products
iPad 2 Bluetooth/Wi-Fi Antenna
$24.95 · 45 In stock
iPhone 4S Display Assembly
$94.95 · 50+ In stock
Flathead 3/32" or 2.5 mm Screwdriver
