Image #1 Image #2 Image #3
Add Note Edit Step 17  ¶
  • Use a plastic opening tool or your fingernail to lift up the tab on the rear-facing camera ribbon cable ZIF connector.
    • Make sure you're prying on the tab and not the connector itself.
  • Push the rear-facing camera through its hole in the grey antenna and remove it.
Add Note Edit Step 18 — Front-Facing Camera  ¶
  • Use a plastic opening tool or your fingernail to lift up the tab on the front-facing camera ribbon cable ZIF connector.
  • Lift the front-facing camera out of the antenna with the plastic opening tool and remove it.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Heat Gun
$24.95 · 25 In stock
T5 Torx Screwdriver
$6.95 · 50+ In stock
T4 Torx Screwdriver
$4.95 · 44 In stock
Plastic Opening Tools
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 25 In stock
Inspection Scope
$39.95 · 39 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 18 In stock
Popular Products
iPhone 4S Earpiece Speaker
$24.95 · 36 In stock
Small Suction Cup
26 Bit Driver Kit
$19.95 · 43 In stock
Anti-Static Mat
$24.95 · 50+ In stock
Detailing Brush
$2.95 · 23 In stock
