Installing Motorola Droid 2 Motherboard
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Replace a dead motherboard on your Droid 2.
  • Add Note x
  • x 3
Follow this guide to replace your Droid 2's broken or malfunctioning motherboard.
Sections
Image #1 Image #2 Image #3
  • Slide the battery cover toward the bottom edge of the phone.
  • Remove the battery cover from the rear of the phone.
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Lift the battery out of the Droid 2 from the edge closest to the bottom of the phone.
  • Remove the battery from the Droid 2.
Image #1 Image #2
Add Note Edit Step 3 — Rear Case  ¶
  • Using the tip of a spudger, peel up one corner of the silver ribbon below the battery compartment.
  • Peel the ribbon off the phone.
Image #1
Add Note Edit Step 4  ¶
  • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
  • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
Image #1
Add Note Edit Step 5  ¶
  • Use the tip of a spudger to remove the camera bezel stuck to the rear case.
Image #1
Add Note Edit Step 6  ¶
  • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
Image #1
Add Note Edit Step 7  ¶
  • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
Image #1
Add Note Edit Step 8  ¶
  • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
  • Carefully pry the top edge of the rear case up from the rest of the phone.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
T5 Torx Screwdriver
$6.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 7 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
Popular Products
iPad 2 Adhesive Strips
Metal Spudger
T8 Torx Security Bit Screwdriver
