Installing MacBook Unibody Model A1342 Trackpad Replacement
Replace the Trackpad in your MacBook Unibody Model A1342.
  • Add Note x
  • x 24
Image #1
Add Note Edit Step 1 — Lower Case  ¶
  • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
Image #1 Image #2 Image #3
Add Note Edit Step 2  ¶
  • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
  • Slightly lift the lower case near the vent opening.
  • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
  • The location of these three clips is shown in the third picture.
Image #1
Add Note Edit Step 3 — Battery  ¶
  • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  • It may be easier to use your fingernails to lift up on both sides of the connector.
Image #1
Add Note Edit Step 4  ¶
  • Remove two 5 mm Tri-Wing screws securing the battery to the upper case.
Image #1
Add Note Edit Step 5  ¶
  • Use the tip of a spudger to carefully peel back the finger of the warning label to reveal a hidden Tri-Wing screw.
  • Remove the 5 mm Tri-Wing screw securing the battery to the upper case.
Image #1
Add Note Edit Step 6  ¶
  • Remove three 3.1 mm Phillips screws securing the battery near the edge of the upper case.
  • When reinstalling the battery, be sure to install these three screws before proceeding to fasten the Tri-Wing screws.
Image #1
Add Note Edit Step 7  ¶
  • Use the battery's plastic pull tab to lift and remove the battery from the upper case.
Image #1
Add Note Edit Step 8 — Trackpad Replacement  ¶
  • Use the flat end of a spudger to pry the trackpad ribbon cable connector up off the logic board.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Tri-wing Y1 Screwdriver
$9.95 · 50+ In stock
Related Products
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 11 In stock
