Installing MacBook Unibody Model A1342 Clutch Cover
Replace a damaged clutch cover.
- Author: Andrew Bookholt
- Difficulty: Difficult
Remove the clutch cover to access cables terminating inside the display.
Sections
- Lower Case 2 steps
- Battery 1 step
- Rear Vent 3 steps
- Display 8 steps
- Front Display Bezel 5 steps
- Clutch Cover 3 steps
- View:
- Single page
Edit
Step 2
The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
Slightly lift the lower case near the vent opening.
Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
The location of these three clips is shown in the third picture.
Edit
Step 3
Battery
For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
It may be easier to use your fingernails to lift up on both sides of the connector.
Page 1 of 3
