Installing MacBook Unibody Model A1278 LVDS Display Cable
Replace the LVDS display cable in your MacBook Unibody Model A1278.
- Author: Walter Galan
- Difficulty: Moderate
This guide will show you how to replace the LVDS display cable.
Sections
- Access Door 2 steps
- Battery 1 step
- Lower Case 2 steps
- Display Assembly 9 steps
- Front Display Glass 10 steps
- Clutch Cover 2 steps
- LCD Panel 6 steps
- LVDS Display Cable 1 step
- View:
- Single page
Edit
Step 8
Remove the following screws securing the camera data cable and right speaker to the upper case:
One 9.9 mm partially threaded Phillips screw
One 9.6 mm threaded Phillips screw
One 4 mm Phillips screw
Slide the camera cable bracket out from under the subwoofer and remove it from the computer.
The iSight cable has an eyelet through which passes the left-most screw in these pictures.
Page 1 of 5
