Installing MacBook Pro 17" Unibody RAM
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Upgrade your MacBook Pro 17" Unibody's RAM for an instant increase in computer speed.
  • Add Note x
  • x 46
Use this guide to replace your MacBook Pro's RAM.
Sections
Tools
Image #1
Add Note Edit Step 1 — Lower Case  ¶
    • Seven 3 mm Phillips screws.
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Wedge your fingers between the lower case and the vent, and lift upward to release the clips holding the lower case to the upper case.
  • Remove the lower case.
Image #1 Image #2
Add Note Edit Step 3 — Battery  ¶
  • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
  • Grab the plastic tab attached to the battery connector and pull it toward the front edge of the device.
  • Pull the tab parallel to the face of the logic board.
Image #1 Image #2 Image #3
Add Note Edit Step 4 — RAM  ¶
  • Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the RAM.
  • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • After the RAM chip has popped up, pull it straight out of its socket.
  • Repeat this process if a second RAM chip is installed.
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Related Products
PC3-8500 1 GB RAM Chip
$19.95 · 50+ In stock
PC3-8500 4 GB RAM Chip
$99.95 · 47 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 9 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
