Installing MacBook Pro 17" Models A1151 A1212 A1229 and A1261 RAM Shield
  • Add Note x
  • x 4
Removing a few screws will remove this part and allow access to your RAM.
Image #1
  • Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Image #1
Add Note Edit Step 2 — RAM Shield  ¶
  • Remove the four identical Phillips screws from the memory door.
Image #1
Add Note Edit Step 3  ¶
  • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Related Products
MacBook Pro 17" Memory Door
$29.95 · 5 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 17 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
