Image #1 Image #2
Add Note Edit Step 17  ¶
  • Insert the flat end of a spudger into the gap between the rear display bezel and the clutch cover.
  • Twist the spudger to separate the lower edge of the rear display bezel from the clutch cover.
  • Work along the lower edge of the rear bezel until it is evenly separated from the clutch cover.
Image #1 Image #2 Image #3
Add Note Edit Step 18  ¶
  • Now that the right and bottom edges of the rear bezel are slightly separated from the front bezel, use a spudger to pop the rear bezel off the tabs near the lower right corner of the display.
Add Note Edit Step 19  ¶
  • Insert the flat end of a spudger between the front bezel and the plastic strip attached to the rear bezel near the screw holes at the bottom corners of the display.
  • Rotate your spudger toward the rear bezel to separate it from the front bezel.
  • If necessary, continue separating the left edge of the rear bezel off the tabs on the front display bezel.
Image #1
Add Note Edit Step 20  ¶
  • Slightly lift the lower edge of the display and pull it away from the rear display bezel.
  • The rear display bezel remains.
Image #1
Add Note Edit Step 21 — Display Inverter  ¶
  • Remove the piece of tape securing the backlight cables to the front display bezel.
Add Note Edit Step 22  ¶
  • Carefully lift the inverter out of the clutch cover.
Image #1 Image #2
Add Note Edit Step 23  ¶
  • Disconnect the inverter cable by pulling its connector away from the socket on the inverter board.
Image #1 Image #2
Add Note Edit Step 24  ¶
  • Disconnect the backlight connector from the inverter board.
  • Be careful when removing this connector, as it may be firmly seated in its socket.
  • Remove the inverter from the display.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 50+ In stock
Phillips #00 Screwdriver
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 13 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
