Installing MacBook Pro 15" Unibody Mid 2010 Matte Finish LCD
Archived Guide
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
User-Contributed Guide
A procedure for removal and replacement of a MacBook Matte Finish LCD.
  • Author: Mike K
  • Difficulty: Difficult
This guide has been updated by iFixit staff! Read the new, official Installing MacBook Pro 15" Unibody Mid 2010 Matte LCD guide.
This guide covers removal and replacement of the Matte Finish LCD. Aside from your screen not being glossy or glared, you know you have a Matte Finish LCD if you have an approx. 14mm brushed aluminum bezel around your screen.
Most people DON'T have this bezel, and so should use the existing Glossy LCD replacement guide instead: Installing MacBook Pro 15" Unibody Mid 2010 LCD .
The display assemblies of Matte Finish LCD and Glossy LCD version of the MacBook Pro differ in a few ways:
  1. The aluminum bezel.
  2. The actual LCD is different (Matte finish, of course)
  3. The exterior glass of the matte display is optically bonded to the LCD, so you cannot remove the glass with suction cups.
Apart from the display assemblies, the Matte Finish LCD Macbook Pro is identical to a Glossy LCD Macbook Pro of the same screen size.
Note that this guide is marked "difficult". The reason it is marked that way is that you will have to remove the bezel, which is thin aluminum, and the display bumper which is a thin piece of rubber. If you damage these parts (i.e. you put a hard bend in the bezel or tear the bumper), you likely won't be able to get another. This is not necessarily a hard to perform procedure, but could be risky. So please read this guide and consider if it is for you before moving forward.
Image #1
Add Note Edit Step 1 — Display  ¶
  • Use the flat end of a spudger to carefully pry the AirPort/Bluetooth ribbon cable up off its socket on the logic board.
Image #1
Add Note Edit Step 2  ¶
  • Pull the camera cable connector straight out of its socket on the logic board.
  • Pull the cable parallel to the face of the logic board toward the optical drive opening.
Image #1
Add Note Edit Step 3  ¶
  • Use the tip of a spudger to pry the three antenna connectors up off the AirPort/Bluetooth board.
Image #1 Image #2
Add Note Edit Step 4  ¶
  • De-route all three antenna cables from their channels in the AirPort/Bluetooth housing.
  • De-route the camera cable from its channel in the AirPort/Bluetooth housing.
Image #1
Add Note Edit Step 5  ¶
  • Remove the following two screws securing the AirPort/Bluetooth housing to the upper case:
    • One 3.8 mm Phillips
    • One 8.6 mm Phillips
Image #1
Add Note Edit Step 6  ¶
  • Remove the AirPort/Bluetooth assembly from the upper case, minding any cables that may get caught.
Image #1 Image #2
Add Note Edit Step 7  ¶
  • Remove the 8.6 mm Phillips screw securing the antenna/camera cable retainer to the upper case.
  • Remove the antenna/camera cable retainer from the upper case.
Image #1
Add Note Edit Step 8  ¶
  • Remove two of the three 6 mm T6 Torx screws securing the right side of the display to the upper case.
  • We purposely have you leave one screw attaching the display to the upper case to aid in future steps.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 13 In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Hobby Knife
$4.95
Heat Gun
$24.95 · 24 In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 10 In stock
Popular Device Products
Unibody Laptop Dual Drive
$39.95 · 3 In stock
PC3-8500 4 GB RAM Chip
$49.95 · 45 In stock
Arctic Silver Thermal Paste
$8.95 · 50+ In stock
Arctic Silver ArctiClean
$7.95 · 50+ In stock
