Installing MacBook Pro 15" Unibody Late 2011 Heat Sink
Replace your Late 2011 MacBook Pro 15" Unibody's heat sink.
- Author: Matt Wiens
- Difficulty: Difficult
Replacing the heat sink requires removal of the logic board and application of new thermal paste.
Sections
- Lower Case 2 steps
- Battery Connector 2 steps
- Left Fan 3 steps
- Logic Board 15 steps
- Heat Sink 2 steps
Tools
Tools (continued)
Relevant Parts
- View:
- Single page
Edit
Step 3
Battery Connector
For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
Edit
Step 6
Use the flat end of a spudger to disconnect the left fan connector from the logic board.
It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
Page 1 of 3
