Image #1 Image #2
Add Note Edit Step 25  ¶
  • Starting at its far left end, rock the clutch cover along its long axis while pulling it away from the clutch hinge.
  • Working from right to left, carefully continue to release and lift the clutch along the lower edge of the display assembly.
  • Lift the clutch cover up off the front bezel and set it aside.
  • When reinstalling the clutch cover, be sure to widen the opening when slipping it over the small black plastic cosmetic cover that fills the open end of the clutch cover when it is in place. The cosmetic cover has very thin and delicate plastic arms that hold it to the right clutch hinge.
Image #1
Add Note Edit Step 26  ¶
  • Remove the six 2.9 mm Phillips screws securing the LCD panel to the front bezel.
Image #1
Add Note Edit Step 27  ¶
  • Pull the LCD toward the top edge of the display to slide the circuitry along its lower edge out of the recess in the aluminum display assembly.
  • It may be helpful to use one hand to feed the display data cable through its channel in the aluminum display assembly as you pull the LCD toward the top edge of the display with the other hand.
Image #1
Add Note Edit Step 28  ¶
  • Peel the piece of tape covering the display data cable connector away from the edge closest to the LCD.
Image #1 Image #2
Add Note Edit Step 29  ¶
  • Use the tip of a spudger to flip up the thin steel retaining clip securing the display data cable to its socket on the LCD.
  • Pull the display data cable straight away from its socket on the LCD.
  • Lift the LCD out of the display assembly and set it aside.
  • If you are replacing the LVDS/display data cable, simply de-route it from its slot cut into the display casing.
Image #1 Image #2
Add Note Edit Step 30 — Display Data Cable  ¶
  • Carefully pull the display data cable through the recess located near the left hinge.
  • Do not use excessive force to pull the cable through as it may damage the connector.
Image #1
Add Note Edit Step 31  ¶
  • Display data cable remains.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 50+ In stock
Phillips #00 Screwdriver
Heat Gun
$24.95 · 20 In stock
Heavy-duty Suction Cups (Pair)
$14.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 7 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
Popular Device Products
Unibody Laptop Dual Drive
$39.95 · 50+ In stock
Arctic Silver Thermal Paste
$8.95 · 50+ In stock
Arctic Silver ArctiClean
$7.95 · 11 In stock
