Installing MacBook Pro 15" Unibody Early 2011 Lower Case
Replace the lower case on your MacBook Pro 15" Unibody Early 2011.
  • Add Note x
  • x 8
Remove the lower case to access most of your MacBook Pro's internals.
Image #1
Add Note Edit Step 1 — Lower Case  ¶
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
Image #1
Add Note Edit Step 2  ¶
  • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 6 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
