Installing MacBook Pro 15" Unibody Early 2011 Logic Board Replacement
Replace the logic board in your MacBook Pro 15" Unibody Early 2011.
- Author: Walter Galan
- Difficulty: Difficult
Use this guide to replace your bare logic board. This requires removal of every component attached to the logic board.
Sections
- Lower Case 2 steps
- Battery Connector 2 steps
- Battery 3 steps
- Left Fan 3 steps
- Logic Board 15 steps
- Heat Sink 2 steps
- Logic Board Replacement 6 steps
Tools
- View:
- Single page
Edit
Step 3
Battery Connector
For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
Page 1 of 5
