Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Use this guide to install a second hard drive in place of the optical drive.
- Author: Jake Devincenzi
- Difficulty: Moderate
There are many benefits to adding a second hard drive to your laptop such as improved speeds, greater storage space, and less heartache when installing new software. Use this guide to install one using our optical bay hard drive enclosure.
Sections
- Battery 1 step
- RAM Shield 1 step
- Upper Case 7 steps
- Optical Drive 2 steps
- Optical Drive Replacement 3 steps
- Dual Hard Drive 6 steps
Tools
Relevant Parts
- View:
- Single page
Edit
Step 8
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor. These clips can be very difficult to disengage without prying. They can also be difficult to re-engage during reassembly.
Reassembly Tip: Press down firmly on the tip of the top case above the location of each clip until you hear a snap to reseat them in their slots.
Reassembly Tip: The two center DVD clips will rarely snap back into place properly without help, and downward pressure will instead simply deform the frame around the DVD slot. Support the frame by inserting a plastic spudger into the DVD slot directly under the clip location until it is snug, then press down until you hear the snap.
Page 1 of 3
