Installing MacBook Pro 13" Unibody Early 2011 Logic Board Replacement
Replace a fried logic board on your Early 2011 MacBook Pro 13" Unibody.
  • Add Note x
  • x 18
Use this guide to completely replace the logic board.
Image #1
Add Note Edit Step 1 — Lower Case  ¶
  • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
  • Remove the lower case.
Image #1 Image #2
Add Note Edit Step 3 — Battery Connection  ¶
  • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
  • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
Image #1
Add Note Edit Step 4  ¶
  • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
Image #1 Image #2 Image #3
Add Note Edit Step 5 — Fan  ¶
  • Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board.
  • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
  • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
Image #1
Add Note Edit Step 6  ¶
  • Remove the following three screws securing the fan to the logic board:
    • One 7.2 mm T6 Torx screw
    • Two 5.3 mm T6 Torx screws
Image #1
Add Note Edit Step 7  ¶
  • Lift the fan out of its recess in the logic board, minding its cable that may get caught.
Image #1 Image #2
Add Note Edit Step 8 — Logic Board  ¶
  • Use the tip of a spudger to pull the right speaker/subwoofer cable out from under the retaining finger molded into the upper case.
  • Pull the right speaker/subwoofer cable upward to lift the connector out of its socket on the logic board.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 50+ In stock
Phillips #00 Screwdriver
Phillips #1 Screwdriver
$4.95 · 27 In stock
Arctic Silver Thermal Paste
$8.95 · 50+ In stock
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 6 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
