Installing MacBook Core Duo RAM
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
  • Add Note x
  • x 86
Accessing the RAM in this computer is straightforward and requires minimal disassembly. Two RAM slots allow up to 2 GB of PC2-5300 RAM.
Image #1
  • Use a coin to rotate the battery-locking screw 90 degrees clockwise.
Image #1
Add Note Edit Step 2  ¶
  • Lift the battery out of the computer.
Image #1
Add Note Edit Step 3 — Memory Cover  ¶
  • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
  • The screws are captive to the metal memory cover.
Image #1
Add Note Edit Step 4  ¶
  • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
Image #1
Add Note Edit Step 5 — RAM  ¶
  • Pull back on the metal lever and slide the RAM chip out from its compartment.
  • Unlike the iBook line, the MacBook has two RAM slots, which allows for up to 2 GBs of memory.
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Coin
$2.95 · 20 In stock
Related Products
PC2-5300 1 GB RAM Chip
$29.95 · 19 In stock
PC2-5300 512 MB RAM Chip
$19.95 · 11 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 27 In stock
Inspection Scope
$39.95 · 40 In stock
Frictionless Ratchet
$24.95 · 49 In stock
Portable Anti-Static Mat
$24.95 · 19 In stock
