Image #1
Add Note Edit Step 49  ¶
  • Remove the single 3.2 mm Phillips screw securing the display data cable to the right clutch hinge.
Image #1
Add Note Edit Step 50  ¶
  • Move the display data cable out from under the mounting arm of the right clutch hinge.
Image #1
Add Note Edit Step 51  ¶
  • Remove the twelve 4.2 mm Phillips screws securing the LCD assembly to the rear display bezel.
  • Make sure you pay attention to how the microphone cable (and antenna cable on some models) are routed around the outside of the two screws nearest to the bottom of the screen (on both left and right). It's easy to damage the cables if not routed properly when putting these screws back on.
Image #1
Add Note Edit Step 52  ¶
  • Lift the LCD assembly out of the rear display bezel, minding any cables that may get caught.
Image #1
Add Note Edit Step 53  ¶
  • Be sure to keep track of the small magnet along the left side of the display. It may be stuck to the LCD frames or to the rear display bezel. When installing it, be sure short side is facing upward.
Image #1
Add Note Edit Step 54 — Right Clutch Hinge  ¶
  • Remove the three 3.2 mm Phillips screws securing the right clutch hinge to the rear display bezel.
Image #1
Add Note Edit Step 55  ¶
  • Lift the right clutch hinge out of the rear display bezel.
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Spudger
$2.95 · 50+ In stock
Coin
$2.95 · 20 In stock
Plastic Cards
$2.95 · 38 In stock
Related Products
MacBook Right Clutch Hinge
$39.95 · 7 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 19 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
